Disables VPEX mode for using bridge port extenders (BPEs).
| vpex | Specifies Virtual Port Extender (VPEX). |
N/A.
Disabling VPEX mode removes all BPE slot number assignments made using configure vpex ports port_list slot slot_num. A reboot of the switch is required for this command to take effect.
The following example disables VPEX mode:
# disable vpex
This command was first available in ExtremeXOS 22.5.
This command is available on ExtremeSwitching 5420 and 5520 series switches, and Extreme 7520-48Y switches.
